Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Just bought Intel 600p SSD for my newly purchased ASUS ROG GL 752 VW but it is not recognized in the UEFI BIOS
I have recently purchased an Intel 600p to use in my newly acquired ASUS ROG GL752VW laptop, but the UEFI bios does not recognise it. This laptop comes with an M.2 2280 slot, and is NVMe compliant. Can anyone shed any light on this problem.
GMele
I had the same issue with the ASUS ROG 702V. You need to turn off Secure Boot and then you will see the option to change the setting to enable the use of the 600p. I haven't tried turning Secure Boot back on but haven't bothered with it.
P.S. Loving the 600p - great, amazingly fast drive for a great price
Community Manager
Hello D3nnis48,
After checking all the specs of your system we can determine that this one is fully compatible and it should work fine with your SSD.
One recommendation we always provide is to have the latest BIOS installed.
The suggestion Abantech provided is correct, you may want to double check your BIOS settings and disable the option that shows as "Fast Boot", we have seen cases where this feature needs to be disabled so it can be detected.
Please let us know if it works for you.
Nestor C
Community Manager
Hi D3nnis48,
We are following up the thread and we'd like to know if you require further assistance.
We'll be waiting for your response.
Nestor C
NDimi
Hi d3nnis48
I also had a problem with my 600p SSD on my laptop. I've tried a bunch of solutions previously mentioned on different forums all over the net (EaseUS Todo Backup Free, AOMEI Backupper and other).
What finally worked for me EaseUS Partition Master 11.9 http://download.easeus.com/trial/epm_trial.exe http://download.easeus.com/trial/epm_trial.exe ,
I got a license key from https://www.humblebundle.com/ Humble Software Bundle for PC Lovers (pay what you want and help charity) it only cost around 6$ (bundled with additional software, awesome bundle especially since it came with other programs like System Mechanic 16.5 which optimized my system before the actual OS migration).
In EaseUS Partition Master 11.9 I started the option Migrate OS to SSD, it automatically detected the 600p SSD and did all of the following steps on its own. I just clicked restart when it asked to restart, and from there the migration continued. I went to sleep and in the morning the computer was waiting for me with all of the files migrated to the SSD and even didn't had to change the boot priority in the BIOS since the EaseUS Partition Master did that already.
Now I'm enjoying the blistering speeds of the Boot-able SSD and my 1 TB HDD is now my storage drive.
Hope this will help you too.
MadBuldog
Community Manager
Hi MadBuldog,
Thanks for your input on this thread, hope this really works for d3nnis48.
Nestor C
