I have been doing quite a bit of research about SSD drives in the enterprise. I have some larger 16 drive arrays that I am using for virtualization. The question has come up do the Intel drives do anything to let me know they have reached the TBW number. I am running 50 VMs on the array and since there are multiple VMs the actual usage is very variable. I don't see anything happening for a few years but I also know budgets and they will not replace the drive until they have to.
Do the SSD drives go into read only mode, provide a warning that they are reaching the limit or nothing?
Hello komondor,
Thank you for contacting Intel® Technical Support.
To answer your questions:
- When the "Endurance Rating (Lifetime Writes)" measure is reached the SSD will be on read-only mode.
- Intel provides different tools to measure the life status of your SSDs like the https://downloadcenter.intel.com/download/28234/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox and the https://downloadcenter.intel.com/download/28286/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=87278 Intel® SSD Data Center Tool (Intel® SSD DCT) or feel free to use any other third party utility to read the SMARTs from your SSD.
- This is a common topic in the VMware* communities and we advise you to review some of the available posts.
- In https://ark.intel.com/# @SolidStateDrives https://ark.intel.com/# @SolidStateDrives you will be able to find the Endurance Rating (Lifetime Writes) of all our SSDs.
We hope you find this information helpful.
Josh B.
Under Contract to Intel Corporation
Hello komondor,
Josh B.
Hello komondor,
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication.
Please let us know if you need further assistance or if we can close this case.
Josh B.
Yes the answer provided was very helpful. I do wish the other vendors I contacted were as forthcoming with the information.
Hello komondor,
Thank you for your reply.
It has been a pleasure to assist you through this process and we are glad to hear that you found the information we shared helpful.
As per your consent, this case is now close if you need further assistance please do not hesitate to contact us.
Josh B.
