Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Losing freespace on SSD X25-M 160GB G2
hello!
I have a 160GB SSD as windows/application. it came to my attention that i currently have only 30 GB left free space, which surprised me. I didnt install much on the drive. So I started to investigate it;
opened a dosbox and did: dir * /s; the result:
Total Files Listed:
142356 File(s) 30,204,940,918 bytes
61206 Dir(s) 32,397,701,120 bytes free
30GB with files and 32GB free = 62GB on a 160GB drive, I miss almost 100GB of space!
I tried with Treesize pro, showed same result. 100GB seems to be missing.
Checked the firware (Intel SSD toolbox, word 23-26); 2CV102G9
which seems ok.
What can i do to reclaim the 100Gb ?
thanks in advance,
Sander
Community Manager
forgot the system specs;
Asus P6T Deluxe, i7 920, 6GB, GTX260-218 55nm, intel SSD X25-M 160GB G2
Community Manager
I got 10GB extra back by deleting windows 7 restore points. ( http://www.winhelponline.com/blog/how-to-delete-system-restore-points-windows-7/ http://www.winhelponline.com/blog/how-to-delete-system-restore-points-windows-7/ )
so the score is now:
Total Files Listed:
142506 File(s) 30,200,760,844 bytes
61164 Dir(s) 40,100,790,272 bytes free
30+40 = 70Gb on a 160 GB drive, 90GB is unaccounted for.
anyone a suggestion?
thanks in advance
Sander
Community Manager
Community Manager
found it! ran treesize pro as admin, (does NOT work when you run a dosbox as admin and do dir * /s)
It has nothing to do with my SSD. its thanks to windows 7
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player\Art Cache
2.1 Million files in one directory! thanks Media Player!
ill try to find out what causes it. and find out how to delete them, for the sake of completion. i'll post the solution here.
thanks,
Sander
Community Manager
You can try running Crap Cleaner to delete those files--it does delete stuff from Windows Media Player.
Community Manager
deleting was easy, and 100% straight forward;
I browsed to the directory, right clck LocalMLS and
press shift while choosing delete, resolved the issue (although it took 30
minutes to delete even on SSD it saved up 78GB of space.)
thanks all!
regards
Sander
