Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Low write speeds on Intel 1.8" 320 SSD (300GB)
I'm having problems with my new Intel 1.8" 320 SSD (300GB). I was very careful when I installed it to do a completely clean installation of Windows 7 to ensure I had properly aligned partitions and that the disk remained properly TRIMed. I have a Sony VAIO TT laptop which will only operate in AHCI mode (there is no IDE mode option). Now that I've installed quite a bit of software its not performing as it should. In particular the write speeds are very low especially at large transaction sizes. I've run the ATTO Disk Benchmark several times and it always gives something close to the first image. I did run the benchmark once before I started installing lots of software and it didn't do this (write speeds were 200MB/s+ all the way up to 8MB transactions). Unfortunately I didn't save the results. I have re-run the benchmark in Safe Mode though and I get the results in the second image. Does anyone have any idea what might be going on? What about the speeds for transactions below about 8KB? This link http://www.legitreviews.com/article/1579/4/ http://www.legitreviews.com/article/1579/4/ seems to show much higher speeds than I'm getting.
Community Manager
I decided to do an enhanced secure erase and re-install Windows 7. I ran the benchmark again (this time before installing any new drivers) and I was still seeing low write speeds. I tried a couple of newer drivers for the Intel SATA controller which also seemed to have no effect. Eventually I gave up and just started installing the rest of my drivers and software. I ran the benchmark after every couple of installations just to check it didn't suddenly get better or worse. The strange thing is that it seemed to start getting gradually better. Its almost as if the drive has some housekeeping it needs to do and it chooses to do it when its loaded with large writes. Also whatever housekeeping it is apparently can't be avoided by doing an enhanced secure erase. Maybe this is because the enhanced secure erase only generates new encryption keys and doesn't actually erase the memory cells? If this theory is correct then is there any way to get the drive to actually get this housekeeping over and done with? The optimizer doesn't seem to do it - it runs and completes apparently successfully in just a few seconds. I suspect that the real work is being put off. Maybe this is all a deliberate strategy to eliminate wear? That would make some kind of sense except why do 64KB writes still seem to happen at full speed?
Community Manager
I thought I should update this thread just in case anyone stumbles across it. It would appear that what I've been seeing has nothing to do with the drive itself and is caused by processor power management on my laptop. I thought that having the laptop plugged in would be sufficient but I actually had to switch from the "Balanced" profile to the "High Performance" to get the full performance of this drive in the ATTO benchmark. Other benchmarks might behave differently. I still only get about 10MB/s write and 13MB/s read on 512 byte transactions but I'm assuming this is because my CPU isn't particularly powerful. Sorry if I've wasted anyone's time.
