Community
cancel
Showing results for
Search instead for
Did you mean:
DMurp10
MacBook Pro (13-inch, Mid 2009) compatible with Intel's Solid-State Drive 530 Series (2.5-inch)?
Thanks in advance to all of the help,
I'm looking at swapping out my MacBook Pro's (13-inch, Mid 2009) aging HDD with Intel's Solid-State Drive 530 Series (2.5-inch). I'm trying to find out if the two are compatible? The form factor (2.5-inch) and thickness
(7 mm) seem like a good fit.
~ Darren
Jose_H_Intel1
We recommend contacting the Apple* for a list of validated products for your system.
http://www.intel.com/support/ssdc/hpssd/sb/CS-032001.htm Intel® High Performance Solid-State Drives — Will the Intel® SSD Work in My MacBook?
http://www.intel.com/support/ssdc/hpssd/sb/CS-034877.htm Intel® High Performance Solid-State Drives — Intel® Solid-State Drive (Intel® SSD) and Sandforce* Controller Compatibili…
