cancel
Showing results for
Search instead for
Did you mean:
Matrix Storage RAID Question
Esteemed Contributor III
Hi all - A little confused here -
First - I have 82801JR (ICH10R) controller that isn't listed in the Matrix storage download list. Am I supported or not?
Second, should I use the RAID 0 on the motherboard or the IMSM?
Third, I have a X25M coming soon. When I set it up, should it be configured as IDE/AHCI? When I do that, and if IMSM works with my computer, would I then be able to add another drive to it at a later date and support RAID 0?
2 REPLIES 2
DZand
Contributor III
Here are my answers:
First: Yes
Second: You should create your RAID0 by using the RAID utility, then install the OS by loading/integrating the needed Intel RAID driver (IMSM or ISRT).
Third: As long as you have just 1 SSD, you should run it in AHCI Mode. If you would buy a 2nd SSD later, you will be able to create a RAID0, but I recommend to take the new Intel(R) Rapid Storage Technology (IRST) drivers and not the IMSM ones (much better performance).
ok, so setup with AHCI mode, get the Intel(R) Rapid Storage Technology later on when a 2nd drive comes along and all will be good.
Thanks for helping me out!
Jeff
