cancel
Showing results for
Search instead for
Did you mean:
Media_Wearout_Indicator going up?
AKvis
New Contributor
I have been monitoring Media Wearout Indicator for a while, but I saw something odd in our Munin graphs, so I dumped the output of smartctl every minute and here are the result:
233 Media_Wearout_Indicator 0x0032 091 091 000 Old_age Always - 0
233 Media_Wearout_Indicator 0x0032 092 092 000 Old_age Always - 0
[120 lines with value:092 removed]
I tought the Media_Wearout_Indicator were going down from 100 as the drive were wearing out and that I could expect failure when it hits 0 - how is it going up again?! The value have been on 091 all the time since I've started monitoring it, but like the above, the value is 092 for a couple of hours before going down to 091 again...
=== START OF INFORMATION SECTION ===
Device Model: INTEL SSDSA2M120G2GC
Serial Number: ******************
Firmware Version: 2CV102HD
User Capacity: 120,034,123,776 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 1
Local Time is: Tue Jul 2 14:39:14 2013 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
/Anders
5 REPLIES 5
Jose_H_Intel1
Valued Contributor II
At this time there are no plans to release software for other operating systems.
You may let us know about the results in case you have the possibility to schedule a downtime for testing.
