Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
My Intel 320 120GB is slow....
I just bought an Intel 320 120GB, but I'm not happy with the benchmark-results I get.
Im running Windows 7 on a laptop, but I don't believe AHCI is enabled. I can't find it as an option in my BIOS.
My laptop: HP Compaq CQ50-110EO.
Even though AHCI isn't enabled, I don't believe I should get these results.
Performing some benchmarks:
AS SSD: http://imageshack.us/photo/my-images/860/asssd.png/ http://imageshack.us/photo/my-images/860/asssd.png/
CrystalDiskMark: http://imageshack.us/photo/my-images/706/crystaldiskmark2.png/ http://imageshack.us/photo/my-images/706/crystaldiskmark2.png/
I have run Intel SSD Optimizer, enabled Trim, disabled Defragmentation, Superfetch, Prefetch and ReadyBoost.
What do you say about the performance of my SSD?
Is there a way to fix it?
Very grateful for help!
Community Manager
It looks like that laptop uses an NVIDIA chipset. Unfortunately, NVIDIA SATA controllers do not fully support AHCI and is limiting the performance of the SSD.
If you plug your Intel 320 into a system with an Intel/AMD controller with AHCI, you should see much better performance.... the sequential writes will be higher and the 4K numbers will be up.
Community Manager
I have the same issue besides applications freezing. What's the most compatible Intel/AMD PCI controller for this type of SSD?
Thanks!
Community Manager
Intel does not produce PCI storage controllers.
I would also advise you not to use a PCI controller because:
1) Most are ancient with limited driver support
2) PCI is limited to 133MB/s for the entire bus. All devices on the bus share that avaliable bandwidth so your SSD will be bottlenecked.
Community Manager
Thanks for the advice. I'll be looking at getting a Hybrid HDD instead and save the SSD for the nest PC. Any recommendation on an excellent Hybrid compatible with XPS720?
