Community
cancel
Showing results for
Search instead for
Did you mean:
KKasa2
My Intel 545s seems to begin breaking
I bought my Intel 545s SSD half a year ago, and attached to my laptop.
While I use my laptop with 545s, the number of "Program Fail Count" keeps increasing. It reached 000000000015 recently.
In addition, the number of "Power On Hours" seems not to be increasing. I think it must be at least 500 hours.
Is it safe to continue using this SSD?
545s is my first SSD and I 'm not so familiar with it. Please give me some advice.
CrystalDiskInfo 7.1.0 (C) 2008-2016 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 10 [10.0 Build 16299] (x64)
Date : 2018/04/19 18:58:18
-- Controller Map ----------------------------------------------------------
+ Intel(R) 6th Generation Core Processor Family Platform I/O SATA AHCI Controller [ATA]
- INTEL SSDSC2KW512G8
- Microsoft 記憶域コントローラー [SCSI]
-- Disk List ---------------------------------------------------------------
(1) INTEL SSDSC2KW512G8 : 512.1 GB [0/0/0, pd1] - il
Model : INTEL SSDSC2KW512G8
Firmware : LHF002C
Serial Number : [Hided]
Disk Size : 512.1 GB (8.4/137.4/512.1/512.1)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 1000215216
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-3
Minor Version : ----
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 269 hours
Power On Count : 885 count
Host Reads : 3861 GB
Host Writes : 2139 GB
NAND Writes : 1833 GB
Temperature : 24 C (75 F)
Health Status : Good (98 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM, DevSleep
APM Level : 00FEh [ON]
AAM Level : ----
Drive Letter : C:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 __0 000000000015 Re-Allocated Sector Count
09 100 100 __0 00000000010D Power-On Hours Count
0C 100 100 __0 000000000375 Power Cycle Count
AA _98 _98 _10 000000000000 Available Reserved Space
AB _96 _96 __0 000000000015 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD 100 100 __5 000200120000 Vendor Specific
AE 100 100 __0 000000000006 Unexpected Power Loss
B7 100 100 __0 000000000000 SATA Downshift Count
B8 100 100 _90 000000000000 End to End Error Detection Count
BB 100 100 __0 000000000000 Uncorrectable Error Count
BE _24 _41 __0 000800290018 Temperature
C0 100 100 __0 000000000006 Unsafe Shutdown Count
C7 100 100 __0 000000000000 CRC Error Count
E1 100 100 __0 000000010B6B Host Writes
E2 100 100 __0 000000000000 Timed Workload Media Wear
E3 100 100 __0 000000000000 Timed Workload Host Read/Write Ratio
E4 100 100 __0 000000000000 Timed Workload Timer
E8 _98 _98 _10 000000000000 Available Reserved Space
E9 100 100 __0 000000000000 Media Wearout Indicator
EC 100 100 __0 000000000000 Vendor Specific
F1 100 100 __0 000000010B6B Total LBAs Written
F2 100 100 __0 00000001E2AB Total LBAs Read
F9 100 100 __0 000000000729 Total NAND Writes
FC 100 100 __0 000000000002 Vendor Specific
AlHill
https://downloadcenter.intel.com/download/27656/Intel-Solid-State-Drive-Toolbox?v=t Download Intel® Solid State Drive Toolbox , run, and report back the findings.
Also, I do not recommend running some third party tool from any web site, especially .info.
Doc
KKasa2
Thank you for your advice. I expoted the data.
AlHill
Thanks for the report. One of the Intel support staff will respond.
Doc
Community Manager
Hello Kasai,
Thanks for providing the S.M.A.R.T. log for your SSD.
Have you noticed any performance issues related to your Intel® SSD 545s? The S.M.A.R.T. attributes values reflect the drive is healthy. (E9) Media Wearout Indicator, one of the main attributes to measure the drive's health has not been reduced.
Eugenio F.
KKasa2
Thank you for replying. I have never noticed any other issues yet.
Sorry, I don't understand what you meant.
Which did you meant, "Even though Program Fail Count is high, it's safe because Media Wearout Indicator has not reduced" or "It's normal that Program Fail Count increases at this pace"?
Community Manager
Hello Kasai,
The S.M.A.R.T. attribute (AB) Program Fail Count is an informational parameter, not a pre-fail value. However, if you notice that this and other attributes keep degrading at a fast pace, please https://www.intel.co.jp/content/www/jp/ja/support/contact-support.html?_ga=2.97677855.1671289199.152... contact your local support to confirm if the drive applies for a warranty replacement.
Eugenio F.
