cancel
Showing results for
Search instead for
Did you mean:
My intel 660p ssd is being blocked from running. How do I get it to be unblocked by my task manager?
VDici
New Contributor
1 ACCEPTED SOLUTION
LeonWaksman
Contributor II
Hi @VDici​
  1. It is not clear to which driver you have on your mind? Do you intend to the NVMe driver in the Storage controllers category of Device Manager? If the answer is yes, uninstall the Intel driver you have installed and use the Microsoft driver build in the O.S. Your SSD will be recognized correctly. If you prefer Intel driver, download it from Intel Client NVMe Microsoft Windows Drivers for Intel® SSDs
  2. Download and install Intel SSD Toolbox. With this application you will be able to check the SSD status and update firmware to the latest version.
Leon
5 REPLIES 5
VDici
New Contributor
That actually worked thanks for the help
