cancel
Showing results for
Search instead for
Did you mean:
My question Is INTEL® SSD D3-S4510 SERIES (960GB, 2.5in SATA 6Gb/s, 3D2, TLC) is compatible in HP Ml350p gen8 ? thanks
jsta
New Contributor
1 ACCEPTED SOLUTION
DiegoV_Intel
Contributor II
Hi jsta, Thank you for posting in the Intel® communities. Unfortunately, we cannot guarantee if the drive will work on that specific platform. You would have to contact HP* directly to confirm the compatibility of the drive. From our side, you can check the compatibility of this drive with our platforms in the following site: https://ark.intel.com/products/134912/Intel-SSD-D3-S4510-Series-960GB-2-5in-SATA-6Gb-s-3D2-TLC- Have a nice day. Regards, Diego V. Intel Customer Support Technician Under Contract to Intel Corporation
1 REPLY 1
DiegoV_Intel
Contributor II
