Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
My system BIOS gives a "No memory" error with a DC P3700 PCIe drive installed
ROBERT_S_Intel
I have an older Intel system (~5-6 years) that has a revision 2.0 PCIe slot. The system will not boot to BIOS & beeps indicating a "No memory" error when my P3700 is installed. The latest BIOS is dated July 2013 so I have to assume it should recognize this drive. The P3700 specs indicate that it's revision 3.0 but is backwards compatible. The OS is Win 7 but it errors when power is turned on. Any ideas why?
Thanks, Bob
Kevin_M_Intel
Hello bsurratt,
I am sorry you are having this problem but let me help you.
I would like to know for troubleshooting purposes, what is the system brand and model you have?
Kevin M
ROBERT_S_Intel
  1. The system is Smackover & the model is a DX58SO. Everything
    I've read says that the P3700 should work but the BIOS beeps with the no memory
    error. I even removed the DIMMs thinking that maybe they were the issue but had
    the same results :-(
Kevin_M_Intel
Thank you for the information. I am going to research about this and I will be back with more updates.
Kevin M
Kevin_M_Intel
I am sorry for the delay on coming back to you.
The P3xxx drives require PCIe 3.0 so it will have problems to work in the DX58SO.
This is documented in the Product Brief under "Interface" on page 2.
http://www.intel.com/content/www/us/en/solid-state-drives/ssd-dc-p3700-spec.html http://www.intel.com/content/www/us/en/solid-state-drives/ssd-dc-p3700-spec.html
Kevin M
ROBERT_S_Intel
Bummer... :-(
Thanks for your help Kevin! :-)
Kevin_M_Intel
