cancel
Showing results for
Search instead for
Did you mean:
Need a new Graphics Driver for Windows 7
Esteemed Contributor III
I believe I have the correct driver for Intel 82815 when using Vista, but having installed Windows 7 the Advisor suggests need AERO support from the Manufacturer to intall new/update of this driver. Can you please help?
1 REPLY 1
Hi there,
If you are using an Intel motherboard you may be able to try to search the latest drivers from the following link: http://downloadcenter.intel.com/default.aspx?iid=subhdr+downloads
If you are using other models of motherboard which has onboard intel graphics chipset, latest drivers may not always work fine. Best is contact the manufacturer of the motherboard.
Hope this is useful.
Cheers
