Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Need help for step-by-step WinXP Intall on Intel 520 180GB SSD
I am quite new to the world of SSD, just purchased a Intel 520 180GB SSD. I plan to install WinXP Pro on this SSD.
I am not sure what software will come with the SSD box. Perhaps I might need to download something.
Could anybody give me step-by-step WinXP installation instruction on SSD? It will be great if the optimization steps are included.
My rig:
WinXP Pro SP3
Intel Yorkfield 9450
Asus P5Q (P45 and ICH10R)
4GB 1066 DDR2
WD 1TB SATA2
Nvidia GTS8800
Thanks in advance!
Dennis
Community Manager
With XP doing a format the partite aligning is not correct for ssd , there are several ways to get good partition aligning .
Make the partition with Gparted , this utility can also correct bad aligning follow the steps in the helpsection http://gparted.sourceforge.net/ http://gparted.sourceforge.net/
It is possible to connect the ssd to a pc with W7 or W8 beta and create the partition in windows, that is the easy way .
The ASSD benchmark utility checks aligning without doing a benchmark http://alex-is.de/PHP/fusion/downloads.php?download_id=9 http://alex-is.de/PHP/fusion/downloads.php?download_id=9
Very useful is a streamlined xp with Intel sata/raid drivers http://www.nliteos.com/ http://www.nliteos.com/
In the bios the setting for ssd is best set on ACHI/RAID ,not the IDE setting .I recommend the raid setting even for a single ssd .
Now install xp on the ssd , use the good aligned partition made earlier . When ready, install the Intel Toolbox
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng%20 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng%20
The toolbox for tweaks and the use of optimizer , XP has no trim . Good aligning is the most important thing
Several tweaks can be found with the ssd tweaker utilitie http://elpamsoft.com/Downloads.aspx?Name=SSD%20Tweaker http://elpamsoft.com/Downloads.aspx?Name=SSD%20Tweaker
