Community
cancel
Showing results for
Search instead for
Did you mean:
pprag
Need help on "Error while reading from the disk" on SSD error
We have a system with followed configuration,
CPU Type: Intel(R) Xeon(R) CPU E5-2667 v3 @ 3.20GHz X 2 //Dual CPUs
Motherboard Name: X10DAI
Motherboard Version: 1.01
Total Physical Memory: 65411MB Kingston RAM
BIOS Manufacturer: American Megatrends Inc
SSD: INTEL SSDSC2BW240H6 , 240GB, Intel 535 Series
Operating System: Windows 7 Professional 64 Bit
Our operating system is installed on SSD,
Problem is when we run BurnInTest, we gets following error
Test Name Cycles Operations Result Errors Last Error
Disk (C:) 13537 69.230 Trillion FAIL 1 Error while reading from the disk
By changing new SSD also we get same error.
What could be the reason, Problem with OS/SSD Lot or OS compatibility on SSD issue?
Please help us to solve our problem.
Thanks in Advance.
Pragnesh Virani
Tags (1)
Community Manager
We have forwarded your post to the SSD community.
ASouz7
Hello PragneshVirani,
We have detected another thread: that seems to be related to the same issue that you are reporting here posted by someone with the same handle as yours. Could you confirm if the thread mentioned above was posted by you regarding the same subject? If so, in order to get replies in a timely manner, our recommendation is to maintain only one thread if related to the same matter.
