Community
cancel
Showing results for
Search instead for
Did you mean:
JDeim
New Intel SSD 520 180GB toolbox there was a warning "Drive health is degraded..."
Jump to solution
I bought new Intel SSD 520 180GB (upgrade my old Intel SSD 320 120GB) and used it with motherboard GIGABYTE 567A-UD5-B3.
After clear setup windows 7 professional 64bit Intel SSD ToolBox there was a warning "Drive health is degraded. Contact your reseller or local Intel representative for assistance" as the following enclosed images.
Please help me what can I do?
Accepted Solutions
Jose_H_Intel1
We have determined this issue is specifically related to the Intel® SSD Toolbox and the drives which ISN starts with EK are not properly identified by the software. The issue is purely cosmetic since there is no problem with the drives, they will operate properly. A new version of Intel® SSD Toolbox will be released soon and include a correction of this issue.
Jose_H_Intel1
I would suggest you to make sure the Intel® SSD 520 is connected to the Intel® SATA controller chipset since the motherboard specifications indicate also a third party SATA/RAID controller.
Otherwise you may contact your local Intel(R) support team for further assistance.
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
JDeim
Thnak for your answer bat i'm sure the Intel® SSD 520 is connected to the Intel® SATA controller.
Jose_H_Intel1
JDeim
I think this answer is satisfactory for me.
I'll check my drive again with the next version of the intel SSD toolbox.
Thank you very much for the help.
Jose_H_Intel1
The Intel® SSD Toolbox 3.1.6 is now available https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 here.
You may also want to check the thread below and provide your results about the incorrect drive health issue.
/thread/43139 http://communities.intel.com/thread/43139
JDeim
I check my drive again with the next version of the Intel® SSD Toolbox 3.1.6 and result about the drive health is well.
Thank you for the help.
