cancel
Showing results for
Search instead for
Did you mean:
New SSD 520 120GB its running kinda slow Pls advise
Esteemed Contributor III
Guys my new ssd is running kinda slow its dont even reaches to the 500mb mark read pls advise. Need help from all the Guru's out there. tyvm
3 REPLIES 3
DShar11
New Contributor II
Looks good to me bud.
If you want to see bigger numbers go to settings tab I think and change to 0-fill data.
Try running ATTO, that should give the 550/500MB/s read/write speeds you're after.
ok tyvm guys.
