Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
New to SSD's
Community Manager
I have built a new computer with 3 SATA HDD's. I have my system on one drive and a Ghost 2003 image on another drive. I am planning to covert my system drive.to a SSD. I am running Windows XP and I am not sure what I need to do. How do I prepair the SSD for install? Can I prepair the SSD, then Ghost the image from my Ghost drive to the SSD?
Community Manager
Hi William,
For an Intel SSD, you shouldn't have to do anything to make it work. You can connect to your system and set it up just like a new hard drive. Or you may image your appropriately sized HD to an SSD just like it were a HD, using a variety of tools including Ghost.
Does that help?
Community Manager
I have read that you have to align the partition on the SSD because XP doesn't set the alignment correctly/.
Community Manager
Your aligment concerns are apporpriate for non-Intel SSDs. But the X-25M and the X25M G2 do not require a correct alignment. The performance differences between "aligned" and "unaligned" will be negligible.
Community Manager
Thank you for the information.
