Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
New to SSD world
I'm very to new to SSD drive. I recently ordered 2 Intel X-25m SSD drives, which im planning to install as OS drive with vista 64 raid0 on an EVGA x58 classified motherboard. The only thing i know is that i have to upgrade the firmware as soon i receive them. Is there any thing else i need to know tweaking (Do's & Dont's post installation) these drive? Also i'm planning to have OS +Apps -- 25 G and DATA (photos and video) 100G on this raid0 partition? I hope there will be remaining 25G free space. Is it advisable to have data on my OS drive? I heard i will loose performance if i fillup space. Is it wrong assumption?
Thanks for any inofmraiton and links.
Community Manager
Do - Consider your motherboard's RAID chipset. Most on-board RAID is designed for redundancy, not performance. If you want RAID0 or RAID1 benefits, seriously consider getting a performance RAID card with a RAM cache (see Adaptec's 5405 card). In any case, test different configurations with benchmarking software before installing all your apps.
Do - utilize a backup system like Norton Ghost to make regular backups of your OS. SSDs, should they fail, tend to fail without warning.
Don't - use any defragmentation software on your SSD drives. Wear-leveling makes this ineffective and wasteful.
Don't - store photos, music, multimedia on the SSDs. Why waste performance SSD storage on static data, unless absolutely critical, when there is cheaper, higher capacity secondary storage available (e.g. external or internal HDDs)?
Recommendation - for the ultimate in OS performance, make room in your budget for something like Gigabyte's iRAM drive or HyperOS's HyperDrive to store your pagefile, TEMP folder, and Temporary Internet Files on. You'd only need 4-8 GB of Ramdisk storage for this purpose (depending on how much physical RAM you have). This DDR-based storage makes your system FLY, and this type of data is not critical enough to warrant backup/redundancy (but enough to cause a performance hit in any other configuration).
These pointers are based on my personal experience with all the hardware I mention, and others.
