cancel
Showing results for
Search instead for
Did you mean:
Newly installed SSD 310 not recognised
Esteemed Contributor III
I have just purchased a new SSD 310 80 gb drive, to speed up boot and programme access times on my Shuttle SX38P2 Pro. Disc would appear to be correctly fitted, I have downloaded the firmware iso, burnt it, booted to it, but the new SSD is not recognised
Where to start? !
Jeremy Poynton
13 REPLIES 13
Which means?
See here
http://skinflint.co.uk/a604215.html http://skinflint.co.uk/a604215.html
Intel SSD 310 Series 80GB, SATA PCIe mini Card (SSDMAEMC080G2C1)
Confused!
Cheers
it means that the 310 will not work. think of msata as an actual sata port that merely looks like a mini pci-e port. sata and pci-e are different protocols, thus the incompatibility.
the specs on that link are misleading.
Cheers. Will have to send it back. That's a drag, never mind
Your advice much appreciated. You wouldn't by any chance be able to suggest a card that would work? As noted, there are, according to Google, SSDs working in the Shuttle model.
Cheers
Jeremy
