Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Non recognized SSD under XP
I just received 2 SSDSA2MH160G2C1.
One of them is supposed to replace the Lenovo T61P HD running under XP SP2.
I installed one as the 2nd HD of this laptop,. It's recongnized in BIOS as HDD1, I can even run BIOS diag on it.
Once XP is started, it's recognized by Device Manager as "Disk drive", though, XP doesn't provide a volume for it and it doesn't appear in the disk drive list in XP explorer.
I tried with the second drive and got the same behavious
Is there a driver I should install ?
Did I miss something obvious ?
Sorry for the duplicate post in French
Community Manager
If you do start -> run -> diskmgmt.msc
Is the disk in there? Is it initialized?
Community Manager
Yes it was, but I had to make it allocated
It's now working fine
Thanks for the info
