Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Not working Turbo boost with SSD 25X-80 g2
MB ASROCK P55 Pro, i7-860, ssd 25x-80 g2 (02HD), Win7-64. If i connect ssd, then Turbo boost not working. Why?
Community Manager
Thats the way its designed.
Community Manager
You mean Ready Boost, right? Turbo Boost is a CPU overclock, and should work with SSD present.
Community Manager
I mean Turbo Boost in my i7-860.
Community Manager
That's real strange. Shouldn't have anything to do with what kind of drive you have in there. Turbo Boost is a cpu function. Ya got me.
Community Manager
If win7 boot from hdd and my ssd not connected - TB working. If win7 boot from hdd and my ssd connected - TB not working. If win7 boot from my ssd - TB not working.
Community Manager
Silly question probably but you are running the latest bios for that board correct? I found an obscure reference on the web that someone else was having the same problem with a regular HDD and updating the bios fixed it. Other than that I am out of ideas. Hope you get it figured out.
Community Manager
<!--  /* Style Definitions */  p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
I guess 6600 means boot, but not boost?
I see in my computer dx58 Turbo boost concern to processor. Try to turn off turbo boost.
Community Manager
What they are saying is that READYBOOST should NOT be used on an SSD. All that constant reading and writing would wear out the drive in about a year.
Community Manager
I have sent the email to techsupport Asrock and to me have answered:
Dear Sir, Thank you for contacting ASRock. Please kindly understand that the archtecture between SSD and regular HDD are different.The symptom you saw is for your to have the best system performance.We also tested MB from other brands such as ASUS and Gigabyte, the results are the same. If there is any update of this case, we would update to you asap. Thank you for your feedback and have a nice day. Your Sincerely,ASRock TSD
Dear Sir,Thank you for contacting ASRock.Please kindly understand that the archtecture between SSD and regular HDD are different.The symptom you saw is for your to have the best system performance.We also tested MB from other brands such as ASUS and Gigabyte, the results are the same.If there is any update of this case, we would update to you asap.Thank you for your feedback and have a nice day.Your Sincerely,ASRock TSD
Community Manager
I have Turbo Key on my ASUS P5Q Pro Turbo board, I wonder if that will be the same, my SSD is in the mail, will follow up when I know for sure,
Community Manager
Turbo boost is new function in new processors i7-860.
