Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
One question on Intel X25-M
<!-- /* Font Definitions */ @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:204; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-520092929 1073786111 9 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; text-align:justify; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Arial","sans-serif"; mso-fareast-font-family:Calibri;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt; font-family:"Arial","sans-serif"; mso-ascii-font-family:Arial; mso-fareast-font-family:Calibri; mso-hansi-font-family:Arial; mso-bidi-font-family:Arial;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
With the latest firmware on board, since Windows 7 already supports trim function, do you still need to use Intel Tool Box and perform optimization once a week?
Thank you
Community Manager
Not if you use either the msahci default driver installed by Windows 7 or the Intel 9.6.0.1014 driver--both for AHCI.
Community Manager
<!--  /* Font Definitions */  @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:204; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:204; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;}  /* Style Definitions */  p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; text-align:justify; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Arial","sans-serif"; mso-fareast-font-family:Calibri; mso-ansi-language:EN-US; mso-fareast-language:EN-US;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt; mso-ascii-font-family:Arial; mso-fareast-font-family:Calibri; mso-hansi-font-family:Arial; mso-bidi-font-family:Arial;} @page Section1 {size:612.0pt 792.0pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} -->
Thank you so much for your reply. Just to make it clear. I have in the Computer Management window, under ATAPI controllers, Standard AHCI serial ATA controller, which was installed by Windows 7. In this case, as you said, there is no need to optimize SSD using Intel Tool Box. But, why in this case Intel provides this tool?
Community Manager
The tool was released ahead of the TRIM-supporting Intel drivers. It is still useful for Windows XP users and W7 users who use non-TRIM capable drivers.
As was said, if you use W7 with TRIM-capable drivers in either AHCI or IDE mode, you don't need the tool anymore.
