Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
Optane 900p Replacement Bracket
MSull3
Is it possible to purchase replacement half height and full height replacement brackets which are Optane specific? I have an Optane 900p 280GB AIC which I need to purchase replacement brackets for.
Ideally, I'd prefer the exact Optane bracket, but found that spare standard "LSI-type bracket" won't work as while the spacing between the holes which the screws insert through is the same,
  • the Optane bracket has a completely flat tab with un-threaded holes for the screws
  • and a standard "LSI-type bracket" has a bit of a lip on the threaded-holes which the screws fasten to.
  • that lip and the threads make it incompatible, but again, I'd prefer to find a replacement Optane bracket.
My search for one has proved unsuccessful, so any help offered would be appreciated! Thanks in advance.
Hello svtkobra7,
Thank you for your interest in the Intel® Optane™ SSD 900P Series.
I understand that you are interested in purchasing half-height and full-height brackets.
According to this link: https://www.intel.com/content/www/us/en/support/articles/000025739/memory-and-storage/enthusiast-ssds.html https://www.intel.com/content/www/us/en/support/articles/000025739/memory-and-storage/enthusiast-ssds.html, the Intel® Optane™ SSD 900P Series (add-in card form factor) comes with a half-height bracket. Could you please further explain why you are interested in purchasing more brackets? Do you have a case of a missing bracket?
I'll be waiting for your response.
Andres V.
MSull3
Sure I'm happy to explain.
I actually only need 1 full height bracket (it was missing you are correct) for my current server (4U = Full Height Bracket). But as I bent the current half height bracket (2U), and as brackets are generally inexpensive, I am interested in purchasing that as well.
I look forward to your response and thanks in advance.
Hello svtkobra7,
Thank you for providing a more detailed explanation of the request.
Since this case involves a missing part, it is out of the scope of this community technical support team, please contact your https://www.intel.com/content/www/us/en/support/contact-support.html local support for further assistance on how to obtain the missing part. Also, they may provide further insight regarding the availability of spare parts.
In case you have another question, don't hesitate to contact us.
Andres V.
