Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Our 910 SSD performance is low.
We are using two of the Intel 910 SSD PCIe drives in a Dell 810 server and getting about 25% of the performance that we would expect. What are we missing? I have used the SSD data center tool and turned up the power, but that only helped a little with write performance. Here is some info on our config;
OS Name Microsoft Windows Server 2008 R2 Datacenter
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name BIDB1
System Manufacturer Dell Inc.
System Model PowerEdge R810
System Type x64-based PC
Processor Intel(R) Xeon(R) CPU E7- 8837 @ 2.67GHz, 2660 Mhz, 8 Core(s), 8 Logical Processor(s)
BIOS Version/Date Dell Inc. 2.4.4, 8/12/2011
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name Not Available
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 256 GB
Total Physical Memory 256 GB
Available Physical Memory 4.66 GB
Total Virtual Memory 264 GB
Available Virtual Memory 12.2 GB
Page File Space 8.00 GB
Page File E:\pagefile.sys
Drive info;
Description Disk drive
Manufacturer (Standard disk drives)
Model INTEL(R) SSD 910 200GB SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 0
Sectors/Track 63
Size 186.31 GB (200,047,034,880 bytes)
Total Cylinders 24,321
Total Sectors 390,716,865
Total Tracks 6,201,855
Tracks/Cylinder 255
Partition Disk # 0, Partition # 0
Partition Size 1.00 MB (1,048,576 bytes)
Partition Starting Offset 17,408 bytes
Partition Disk # 0, Partition # 1
Partition Size 186.19 GB (199,915,395,584 bytes)
Partition Starting Offset 134,235,136 bytes
Bytes/Sector 512
Media Loaded Yes
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 1
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 1, Partition # 0
Partition Disk # 1, Partition # 1
Bytes/Sector 512
Media Loaded Yes
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 2
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 2, Partition # 0
Partition Disk # 2, Partition # 1
Bytes/Sector 512
Media Loaded Yes
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 3
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 3, Partition # 0
Partition Disk # 3, Partition # 1
Bytes/Sector 512
Media Loaded Yes
Partitions 1
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 3
SCSI Target ID 0
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 4, Partition # 0
Partition Size 186.31 GB (200,048,566,784 bytes)
Partition Starting Offset 32,256 bytes
Bytes/Sector 512
Media Loaded Yes
Partitions 1
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 3
SCSI Target ID 1
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 5, Partition # 0
Bytes/Sector 512
Media Loaded Yes
Partitions 1
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 3
SCSI Target ID 2
Sectors/Track 63
Tracks/Cylinder 255
Partition Disk # 6, Partition # 0
Bytes/S...
Tags (1)
