Community
cancel
Showing results for
Search instead for
Did you mean:
JJack7
P3600 firmware fix or enhancements
Jump to solution
Intel NVMe P3600 2.0TB PCIe SSD Adapter SSDPEDME020T4DE Firmware : 8DV10171.
What content is the fimeware 8DV10171 fix or enhancements? Thank you.
Community Manager
Hello Jack_Chen,
According to the information you request about the firmware version: 8DV10171, we can let you know the fixes and enhancements are:
-Added functionality to Enable/Disable latency tracking.
-Added functionality to parse the read and write commands from latency tracking logs
-Added functionality to read and/or modify the SM Bus address for Intel® NVMe* SSD devices only
-Updated power governor settings to add support for new Intel® SSD product SKUs
You can also refer to this https://downloadmirror.intel.com/23931/eng/SSD-DCT_3_0_0_Release_Notes_330715-014US.pdf link in case you need further information.
Now, take into consideration the latest version of the firmware is available in this https://downloadcenter.intel.com/download/26221/Intel-SSD-Data-Center-Tool?v=t link .
Let us know if you require anymore information.
NC
Community Manager
Hello Jack_Chen,
NC
JJack7
Intel NVMe P3600 2.0TB PCIe SSD Adapter SSDPEDME020T4DE firmware 8DV101F0 is latest?
Community Manager
Hello Jack_Chen,
For the Intel® Solid State Drive DC P3600 the latest firmware version is 8DV101F0. That firmware can be installed with the link we provided in the previous post.
Let us know if you need further assistance.
NC
Community Manager
Hello Jack_Chen,
We are following up the thread and we would like to know if you require any further assistance.
We will be waiting for your response.
NC
TTige
As i saw the release note via(https://downloadmirror.intel.com/24739/eng/Intel_SSDDCP3700_P3600_DP04.pdf https://downloadmirror.intel.com/24739/eng/Intel_SSDDCP3700_P3600_DP04.pdf ),
The following firmware upgrades will require 2-step process – 8DV10110 --> 8DV10152 --> 8DV1DP04,
May i know that how can i found the version of 8DV10152 ? Or could you pls provide the download link of 8DV10171?
My product is Intel NVMe P3600 PCIe SSD 2.5in 800GB
Community Manager
Hello TigerLiu,
We will send you some information on the other thread you have opened for this request.
Thread: https://communities.intel.com/thread/107538 https://communities.intel.com/thread/107538
NC
