Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
P45 Express BIOS update
Jo1
I would like to update my current P45 Express Bios, to be able to boot from an SSD installed in a PCIe slot on the motherboard. Can anyone please help to provide me with info on how to do that, and where to get the update firmware? I am using W7Ultimate on a Asus Maximus II Gene M/board.
AlHill
You MUST go to asus for the bios.
AlHill
n_scott_pearson
Super User Retired Employee
What kind of SSD are you referring to? How is this SSD interfacing with the PCIe bus? Please provide specifics (including part numbers for drives and cards used to facilitate this).
If this is a PCIe/NVMe SSD, then you are out of luck. NVMe requires PCIe 3.0 support and your board only has PCIe 2.0. You will not be able to get a BIOS for this board that supports NVMe boot.
