Community
cancel
Showing results for
Search instead for
Did you mean:
LG5
P4500 - How to enable write caching on the device (SSDPE2KX010T7L)
Jump to solution
I'm trying to enable this function in device manager without success (WindowsServer2016). Do I something wronge? What should I do?
Esteban_C_Intel1
Hello LG5, After the research, this is the outcome. Only SATA drives support write caching, the Intel® SSD DC P4500 Series is an NVMe drive, and this technology is not supported for the drive. If you happen to have further questions, feel free to contact us back. Regards, Esteban C Intel Customer Support Technician Under Contract to Intel Corporation
Esteban_C_Intel1
Hello LG5, Thank you for contacting the Intel Communities. In order to give you the most accurate answer for this matter, let me do further research and then get back to you with the outcome. Regards, Esteban C Intel Customer Support Technician Under Contract to Intel Corporation
LG5
Hello Esteban_Intel,
I will wait for the answer. Hopefully it will not take too long ... ;-)
LG5
Esteban_C_Intel1
