Community
cancel
Showing results for
Search instead for
Did you mean:
yout
P4610 NVMe XFS I/O Error ??
Jump to solution
Suddenly XFS I / O error in idle state after 16:00 booting completion on server.
Q1. I want to find the cause of the error.
Q2. If you receive this error, provide a link to a similar case.
The server information is as follows:
Ubuntu 16.04.6 LTS
Kernel 4.4.150- Generic
NVMe P4610 1.6 TB (XFS Format)
The error log is as follows:
Aug 12 15:51:43 mm-ai-df142 kernel: [ 392.330675] Code: 08 c0 ff ff 0f 01 c8 49 8b 80 08 c0 ff ff a8 08 0f 85 2f 01 00 00 e9 07 00 00 00 0f 00 2d 98 b5 9c 00 31 c0 48 89 c1 fb 0f 01 c9 <85> ff 74 15 48 89 f0 b9 48 00 00 00 48 83 c8 01 48 89 c2 48 c1
Aug 12 15:59:36 mm-ai-df142 kernel: [ 865.704633] usb 1-1: USB disconnect, device number 5
Aug 12 15:59:44 mm-ai-df142 kernel: [ 874.055484] usb 1-1: new low-speed USB device number 6 using xhci_hcd
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.250784] usb 1-1: New USB device found, idVendor=04d9, idProduct=a0be
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.250787] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.250866] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.250870] usb 1-1: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.259611] input: HID 04d9:a0be as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:04D9:A0BE.0007/input/input7
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.315628] hid-generic 0003:04D9:A0BE.0007: input,hidraw0: USB HID v1.11 Keyboard [HID 04d9:a0be] on usb-0000:00:14.0-1/input0
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.336051] input: HID 04d9:a0be as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:04D9:A0BE.0008/input/input8
Aug 12 15:59:45 mm-ai-df142 kernel: [ 874.391556] hid-generic 0003:04D9:A0BE.0008: input,hidraw1: USB HID v1.11 Mouse [HID 04d9:a0be] on usb-0000:00:14.0-1/input1
Aug 12 16:00:26 mm-ai-df142 kernel: [ 915.228186] usb 1-1: USB disconnect, device number 6
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.487353] blk_update_request: I/O error, dev nvme0n1, sector 787107632
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.494103] Buffer I/O error on dev nvme0n1p1, logical block 98388198, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.502886] blk_update_request: I/O error, dev nvme0n1, sector 787107640
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.509626] Buffer I/O error on dev nvme0n1p1, logical block 98388199, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.518326] blk_update_request: I/O error, dev nvme0n1, sector 787107648
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.525060] Buffer I/O error on dev nvme0n1p1, logical block 98388200, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.533760] blk_update_request: I/O error, dev nvme0n1, sector 848517408
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.540492] Buffer I/O error on dev nvme0n1p1, logical block 106064420, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.549290] blk_update_request: I/O error, dev nvme0n1, sector 848517416
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.556022] Buffer I/O error on dev nvme0n1p1, logical block 106064421, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.564824] blk_update_request: I/O error, dev nvme0n1, sector 848517424
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.571563] Buffer I/O error on dev nvme0n1p1, logical block 106064422, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.580374] blk_update_request: I/O error, dev nvme0n1, sector 848517432
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.587114] Buffer I/O error on dev nvme0n1p1, logical block 106064423, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.595914] blk_update_request: I/O error, dev nvme0n1, sector 848518048
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.602649] Buffer I/O error on dev nvme0n1p1, logical block 106064500, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.611454] blk_update_request: I/O error, dev nvme0n1, sector 848518056
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.618188] Buffer I/O error on dev nvme0n1p1, logical block 106064501, lost async page write
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.627007] blk_update_request: I/O error, dev nvme0n1, sector 848518064
Aug 12 17:29:05 mm-ai-df142 kernel: [ 6234.633756] Buffer I/O error on dev nvme0n1p1, logical block 106064502, lost async page write
Aug 12 17:29:07 mm-ai-df142 kernel: [ 6236.670633] XFS (nvme0n1p1): metadata I/O error: block 0x5d295fa6 ("xlog_iodone") error 5 numblks 512
Aug 12 17:29:07 mm-ai-df142 kernel: [ 6236.679886] XFS (nvme0n1p1): xfs_do_force_shutdown(0x2) called from line 1197 of file /build/linux-MNTIf1/linux-4.4.0/fs/xfs/xfs_log.c. Return address = 0xffffffffc0647d68
Aug 12 17:29:07 mm-ai-df142 kernel: [ 6236.679931] XFS (nvme0n1p1): Log I/O Error Detected. Shutting down filesystem
Aug 12 17:29:07 mm-ai-df142 kernel: [ 6236.687184] XFS (nvme0n1p1): Please umount the filesystem and rectify the problem(s)
Aug 12 17:29:37 mm-ai-df142 kernel: [ 6266.750101] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:30:07 mm-ai-df142 kernel: [ 6296.829614] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:30:37 mm-ai-df142 kernel: [ 6326.909118] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:31:07 mm-ai-df142 kernel: [ 6356.988617] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:31:37 mm-ai-df142 kernel: [ 6387.068076] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:32:08 mm-ai-df142 kernel: [ 6417.147559] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:32:38 mm-ai-df142 kernel: [ 6447.227053] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Aug 12 17:33:08 mm-ai-df142 kernel: [ 6477.306532] XFS (nvme0n1p1): xfs_log_force: error -5 returned.
Santiago_A_Intel
Hello 3000022912991.565936085680946E12,
Thank you for posting in the Intel® SSD community on your request for support for your Intel® SSD DC P4610 Series (1.6TB, 2.5in PCIe 3.1 x4, 3D2, TLC) drive.
In order to further assist you regarding your inquiry related to your Intel® SSD DC P4610 Series. We will appreciate if you can provide us with the following information:
·        SSU logs, using the Intel® System Support Utility for the Linux* Operating System.
o   Go to https://downloadcenter.intel.com/download/26735/ and download the software.
o   When finished downloading it, open it.
o   Attach the log file obtained to your reply.
·        SMART logs extracted from your Intel® SSD DC P4610 drive.
Please use the Intel® SSD Data Center Tool (Intel® SSD DCT) can be used to read out the SMART attributes; to download this tool, please follow this link: https://downloadcenter.intel.com/download/28639/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=35...
For further information on how to use this tool to extract the SMART logs, please check the User guide: https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_DCT_3_0_x_Use... go to page 25 section 2.1.3.
We will be looking forward to your reply.
Have a nice day.
Santiago A.
Under Contract to Intel Corporation
Santiago_A_Intel
Have a nice day.
Santiago A.
Santiago_A_Intel
Hi 3000022912991.565936085680946E12,
Greetings from Intel® SSD communities support group.
This is a friendly reminder your case remains open, awaiting for your reply.
Have a nice day.
Santiago A.
A Contingent Worker at Intel
Santiago_A_Intel
Greetings from Intel® SSD support group
This is to let you know, this case is being closed.
Please feel free to get back to Intel® communities, whenever you might feel necessary.
Have a nice day,
Santiago A.
