Community
cancel
Showing results for
Search instead for
Did you mean:
JJohn71
PCIe Intel 750 Cache States Question
In the Data Centre Tool you can set Write Cache States on an Intel 750 to 1/2 or 3. Which is the best Cache State to set for performance?
jbenavides
Hello KedarWolf,
The Write cache configuration available with the "isdct set" command is for ATA devices only. It does not apply to the 750, or other PCIe* NVMe* SSDs.
The http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-750-spec.pdf Intel® Solid-State Drive 750 Series are PCIe NVMe* drives, so they are different in many ways from previous generation SSD's. Write cache on this type of drive does not work the same way as previous SSD's and it can't be configured by the user.
You can find more information about this command in thehttps://downloadcenter.intel.com/downloads/eula/23931/Intel-Solid-State-Drive-Data-Center-Tool?httpD... Intel® Solid-State Drive Data Center Tool User Guide, page 20.
