Community
cancel
Showing results for
Search instead for
Did you mean:
PKann1
PCIe SSD pinout queries
We are designing a system to verify the PCIe 3.0 based SSD
Before that we have some doubts while referring the
datasheet,
  1. In Datasheet the pin number 41&43 are shows as
    PETn0, PETp0. Is this pin details represent device's PCIe TX pair or
    host system PCIe TX pair should connect here?
  2. Similarly the pin number 35&37 are shows as PERn0,
    PERp0. Is this pin details represent your device's PCIe RX pair or host
    system PCIe RX pair should connect here?
Kindly clarify the queries.
Thanks & Regards,
P. Rajkumar Kannan.
Community Manager
Hello Kannan.tamil87,
Thanks for posting in our communities. We understand that you have queries regarding where or how to configure pins for PCIe based SSDs.
This forum is for technical support and general information. For design related questions, please refer to our https://www.intel.com/content/www/us/en/design/resource-design-center.html Resource and Design Center.
Eugenio F.
