Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Paragon Alignment Tool (PAT)
Yesterday, I downloaded the Paragon SSD Alignment Tool and whitepaper from their website http://www.paragon-software.com/business/partition-alignment/ http://www.paragon-software.com/business/partition-alignment/ . Yesterday it was free today they charge for the PAT. After cloning my Intel X25-M Mainstream SSDSA2M160G2GC for backup I ran the PAT. No problems encountered. Ran Intel SSD Management Tool then AS SDD benchmark http://www.alex-is.de/PHP/fusion/news.php http://www.alex-is.de/PHP/fusion/news.php. Small performance improvement.
Don't skip taking a backup before trying anying like PAT.
Tags (1)
Community Manager
Below are the results from my previous post's
AS SDD benchmarks http://www.alex-is.de/PHP/fusion/news.php http://www.alex-is.de/PHP/fusion/news.php.
Column 1 shows results before alignment
Column 2 shows results after alignment with Paragon SSD Alignment Tool
Both column 1 and 2 are with controller in IDE mode.
Column 3 is results after AHCI mode enabled.
Community Manager
Community Manager
Well I tried PAT and it said my SSD and HDD were already optimised! well done Windows 7 X64
Community Manager
I run a multi-drive multi-partition XP Pro system. I also run VMWARE Virtual Machines running Win NT, Win XT, Win Server 2003, Vista, and Win 7. I have used PAT to allign all my partitions. Aligning partitions helped improve performance of both applications and Virtual Machines on both SSDs and HDDs. I have found that partition alignment make a significant performance improvement for all the VMs, expecially noticable in reduced boot time.
PAT shows all the partitions in a very nice GUI.
RGiff
Honored Contributor I
I ran the tool yesterday, I though my sys was running good , but when I ran the tool it said I was 12% off, so I let it do it's thing and I picked a pretty good increase in the read writes, Using ATTO before running my XM-25 G2 160 SSD , Was at 107878 write 258819 read , now after running the tool i'm at 114025 write and 269898 read, pretty good increse.
Community Manager
Beware of using PAT if your windows system drive is other than C!
Mine was D: and after running the aligment tool the system wouldn't boot up. I believe it misconfigured the MBR or/and the windows registry. I have spent the whole day to repair this mess.
Now the drive is correctly aligned but I haven't noticed any speed improvement.
