Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Partitioning
Can SSD's be partitioned, would there be any performance loss? Some forums mention something about offsets or alignment having to be set, what does this mean?
If I partitioned an 80GB SSD with a 2GB partition for say, a swap partition that gets written to all the time. Will the SSD's "wear leveling" algorithm work to produce even wear across the entire drive or only on that partition?
