Community
cancel
Showing results for
Search instead for
Did you mean:
PHaml
Please can Intel confirm the typical length of time that data written ONCE ONLY to a SSDSA2bW600G3 600GB 320 Series 2.5" SATA SSD may be expected to be retained?
If an SSDSA2bW600G3 600GB 320 Series 2.5" SATA SSD is written to only once - but is only expected to be subjected to around 20-30 reads during its lifetime, then please can Intel confirm the typical time that the data is likely to be preserved intact before data degradation occurs?
JosafathB_Intel
Hello PHaml Thank you for contacting Intel® Memory & Storage Support. We are going to be working on reviewing your inquiry. We will be contacting you back as soon as we have an update or in case that further information is required. Have a nice day. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello PHaml
Thank you for your patience.
Please find attached to this post two public documents that will clarify and provide you with information regarding the SSDs data retention capabilities, if the drive is powered OFF.
If powered ON – and in this case, only one write plus the SSD performs background activities – no research exists to know how long the drive will last- however it is expected to last well beyond its 5 yr warranty.
We hope you find this information helpful. If you have future questions, please don’t hesitate to contact us. We will be more than happy to help you in any way we can.
Have a nice day.
Josh B.
JosafathB_Intel
posted a file.
JosafathB_Intel
Hello PHaml, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello PHaml, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
