cancel
Showing results for
Search instead for
Did you mean:
Please help! RST issue...
Esteemed Contributor III
Ok... I have a Gigabyte GA-Z68X-UD3H-B3 board with the latest bios (F4).
I had a
750GB WD Black Edition WD7502AAEX
and a
64GB Crucial CT064M4SSD2 (latest firmware, 002)
working just fine with the RST tech!! Maximized cache and working great.
Unfortunatley the 750GB DIED!!!
I replaced it with an even newer (mfg date June 2011) 500GB WD drive.
I cannot get it to work with the SSD in RST. I updated to an even newer version of the RST software, reloaded OS completely, ALL latest drivers for everything.
In the BIOS I have disabeled the Gigabyte XHD (I've tried it with enabled too), I'm in RAID mode and the Intel Raid config utility shows all the disks as NON-RAID.
When I get to Windows, I can start the RST and it will "allow" me to configure the 500GB hard drive for acceleration -- but it never "takes". I also have a "slave" 640GB on port 3 which it WILL let me accelerate... however that is just an extra storage drive I threw in the system.
If I try to accelerate the 640GB it will actually take. The 500GB it gives me the option, but it after pressing ok, basically nothing happens.
I have been to the bios raid config and removed the raid config from all drives for a "clean slate" but to no avail. (the ssd will show up as "cache" in raid util after setting it in windows and rebooting.)
Demonstration video of issue: http://www.youtube.com/watch?v=CEw0rMRuxuI http://www.youtube.com/watch?v=CEw0rMRuxuI
Thanks for your comments or suggestions.
If you have any ideas or suggestions please let me know. I'm tearing my hair out here. Very frustrated because I just had the other drive that was working crash... and after reloading rebuilding... I have this issue!
2 REPLIES 2
MBall5
Contributor
On this case I suggest you to check the Intel® Smart Response Technology User Guide at the following link:
http://download.intel.com/support/motherboards/desktop/dz68db/sb/intel_smart_response_technology_use... http://download.intel.com/support/motherboards/desktop/dz68db/sb/intel_smart_response_technology_use...
This explain exactly step by step how to configure the Intel Smart response technology
Thank you for taking the time to reply... I certainly do appreciate any and all input.
The strange thing here is that I am able to accelerate the other (storage) drive no problem. Additionally I was able to accelerate the previous system drive before it went kaput.
The new drive is a Western Digital WD5002AALX-00J37A0. It is a BRAND NEW model, mfg date June 2011 and I think its exact model/firmware may just not be supported for some strange obscure/minute reason... I am hoping someone in Intel would see this and investigate, it is a very strange issue which I tried to demonstrate in the video.
I've taken additional steps since... I have fully scanned the spindle drive for any errors, defragged it, updated to F8 Bios (the board is a Gigabyte GAZ68-UD3H-B3) which just came out a few days ago, loaded defaults in the BIOS and then carefully reset everything to the correct settings taking care to reference the Intel RST instructions.
Today I even removed the storage drive and swapped the SSD and 500GB harddrive's ports to no avail. RST detects it and attempts to accelerate it - there's every indication that it's going to work, but then it doesn't.
