cancel
Showing results for
Search instead for
Did you mean:
Please help .... unable to run Intel SSD Toolbox!
Esteemed Contributor III
In the past, I have no issue running the Intel SSD Toolbox utilities but get this error below today:
If click Continue, it leads to another error message as below:
Please advise should I need to wipe and and fresh install all or need to rma?
Appreciate your reply. Thank
7 REPLIES 7
vt5
New Contributor III
New Contributor III
have you tried reinstalling the SSD toolbox? any new software installed lately?
Yes, re-install the older version 2.01 and still the same. Will try 2.02 when home from work.
vt5
New Contributor III
New Contributor III
if you have an extra machine, you can try installling the ssd on that machine to further isolate the problem
Did install latest version of Intel SSD Toolbox but still no go.
Even cloned back from back up hard disk also facing same issue.
