Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Please optimize my benchmarks
SSD: Intel 320 80GB (no problems, yet )
Motherboard: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP35+Pro&fMTYPE=LGA775 Abit IP35 Pro
Drivers used: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20624&ProdId=2101&lang=eng&OSVersion=... iata_enu_10.8.0.1003
I'm new to SSDs. My BIOS is in RAID mode, which I'm assuming also enables AHCI. My SSD toolbox says I'm optimized and have the latest firmware as of this writing. I've followed all SSD optimizations listed http://www.tech-forums.net/pc/f128/ssd-tweak-guide-236563/ here. My write performance is slow. What could I be doing wrong?
Community Manager
Your setup in RAID mode with the IRST driver is fine, RAID and AHCI mode are identical for single SSD performance. Your test results are fine, the sequential read and write figures are right at the specs for your 320, which is up to 90MB/s for sequential write speed, even a bit better.
What are you considering to be low write speeds, and why?
