Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Power Connector type for X-18M
I apologize if this is a repeat. I cannot for the life of me find the correct SATA power connector for the X-18M I received. It is not a standard SATA power connector as the key is located inboard between P7 and P8.
It is also not a "slimline" SATA power connector, I've tried that too. Does anyone know what this power connector is called and where one can buy a convertor or cable that works?
Thank you in advance,
Caleb
Tags (1)
A_L_Intel
The 1.8" connector also goes by the spec name "micro-SATA". While I can't recommend any particular brands, a search for this string should get you started.
south
Community Manager
