Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Power requirements/consumption, Series 320?
I recently bought a 320 series 120GB drive to replace an non-working drive on my son's gateway laptop.
On line I saw the power consumption was ACTIVE: 150mW, Idle 100mW, and I also found this in other online literature (retailer's website? (that's 0.03 Amps active @ 5V) It is in Intel's PRODUCT BRIEF Intel® Solid-State Drive 320 Series Non-Volatile Memory Storage Solutions from Intel, file name 325212.pdf
I got the version with the USB 3.0 / SATA converter. It comes with two USB plugs, and it needs them, using just one and the laptop complains the USB is drawing too much power, that would be over 2.5W. I just can't believe this USB/SATA converter is drawing that much power, more than (2.5 - .15 = 2.35W).
The drive itself on its label is marked DC 5V 1A.
The drive does get quite warm after a while.
Now Intel on their SSD webpage says SSDs use less battery power than normal spinning HD's (http://www.intel.com/design/flash/nand/overview.htm http://www.intel.com/design/flash/nand/overview.htm, http://www.intel.com/design/flash/nand/index.htm http://www.intel.com/design/flash/nand/index.htm). But a quick check says most spinning HDs are listed using 500mA or less.
So what is the power consumption of 320 Series SSDs?
From it getting quite warm, the need for two USB plugs (unless the USB/SATA doggle takes 500mA, I doubt it), the drive label itself saying 1A, I tend to believe this.
So where does Intel Product Brief and web site get their info (saying less than spinning HD)
Tags (1)
Community Manager
From http://www.anandtech.com/show/4244/intel-ssd-320-review/12 what I've seen the power consumption figures listed by Intel seem a bit optimisitc. On the other hand the claim that it uses less power seems defensible, since the claimed power consumption of hard drives are optimistic as well.
Community Manager
Classic MHDDs use around 450-500mA of power while they idle, and more during I/O operations.
However, many MHDDs draw http://www.datarecoverytools.co.uk/data-recovery-vocabulary/vocabulary-r-z/spindle-motor-power-usage... nearly 2A of power during spin-up, which is pretty hefty. You can read a white paper on http://www.cl.cam.ac.uk/~acr31/pubs/hylick-harddrive2.pdf MHDD power analysis if you want. Voltage-wise, MHDDs use both the 5V and 12V pins on their http://en.wikipedia.org/wiki/Serial_ATA# Standard_connector SATA power connector (or on their 4-pin Molex if the drive is an older model or PATA), while SSDs tend to just use the 5V line.
Regarding the SSD, since you're using it as a comparative model: there's no spin-up (no spindle motor, no platters), so drive power is more or less consistent from the moment of power-on. However, you're forgetting something: a SATA-to-USB3.0 adapter would require a SATA-to-USB conversion ASIC (basically a processor). Are you aware of how much power that ASIC can draw? Chances are that is what's responsible for most of the power draw.
Let's also not forget that with the introduction of USB 3.0, the default unit load is 150mA (that's a 50% increase over USB 2.0), so that's going to skew your comparisons as well.
Finally, regarding drive warmth: yes, this is normal. All SSDs get warm, regardless of who makes them (OCZ, Intel, Crucial, Corsair, etc.). This is due to the underlying controllers used; the term "warm" here is basically vague. When I touch a MHDD, "warm" would mean it's running at about 32C or so. SSDs run much cooler than that on average, but they are not cold. If you thought SSDs would be cold at all times, you thought wrong. :-)
Community Manager
I broke down and measured the current. I only measured 15 mA! That was during reads. I read a little less during idle. Since the drive is for a windows computer and the easiest way for me to measure the actual current was on my DeskTop Mac, I could not measure the current during writes.
