cancel
Showing results for
Search instead for
Did you mean:
Problem during the toolbox's Installation
Esteemed Contributor III
Hi.
I just changed my PC and I wanted to install the SSD Toolbox in order to run the TRIM on My X25-M 80Go as I did why my older PC.
But at the end of the installation I get an error message saying the instllation can't end with the error code 0xc0000005.
I tried to find what this error is but the only thing I found was about a RAM problem.
But it succeded the memtest86+ so I think it's not the reason.
I have no more idea.
I'm still using Windows XP SP3 and it used to work before I made format c:.
My firmware version is 02HD
Sorry for my english, I'm french.
Thank you for your help.
6 REPLIES 6
What Sata port do you have the SSD it connected too? Try moving it to another one.
My Motherboard is : ASUS M4A87TD/USB3, with the latest BIOS.
My OS, as I said before, is Windows XP SP3 and is up to date.
My SSD Firmware is 02HD.
The SSD is connected on the first S-ATA connector.
Still have the same problem on the third connector.
