Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem during the toolbox's Installation
Hi.
I just changed my PC and I wanted to install the SSD Toolbox in order to run the TRIM on My X25-M 80Go as I did why my older PC.
But at the end of the installation I get an error message saying the instllation can't end with the error code 0xc0000005.
I tried to find what this error is but the only thing I found was about a RAM problem.
But it succeded the memtest86+ so I think it's not the reason.
I have no more idea.
I'm still using Windows XP SP3 and it used to work before I made format c:.
My firmware version is 02HD
Sorry for my english, I'm french.
Thank you for your help.
Community Manager
I have the same problem (same configuration too).
Community Manager
You get a BSoD with error code 0xc0000005 during the install of the SSD Toolbox?
Is your motherboard BIOS, OS, and storage driver up-to-date?
Does Event Viewer give you anymore details on the error?
Community Manager
Hi !
I dont get a BSOD, it's only an error box with this error code.
My BIOS, OS and SSD firmware are all up to date.
Here is what I get in the event viewer :
Type de l'événement : Informations
Source de l'événement : Application Popup
Catégorie de l'événement : Aucun
ID de l'événement : 26
Date : 11/01/2011
Heure : 08:46:46
Utilisateur : N/A
Ordinateur : PERSO
Description :
Application popup : Intel SSD Toolbox.exe - Erreur d'application : L'application n'a pas réussi à s'initialiser correctement (0xc0000005). Cliquez sur OK pour arrêter l'application.
Pour plus d'informations, consultez le centre Aide et support à l'adresse http://go.microsoft.com/fwlink/events.asp http://go.microsoft.com/fwlink/events.asp.
I can't see any more information.
Community Manager
What motherboard?
Community Manager
What Sata port do you have the SSD it connected too? Try moving it to another one.
Community Manager
My Motherboard is : ASUS M4A87TD/USB3, with the latest BIOS.
My OS, as I said before, is Windows XP SP3 and is up to date.
My SSD Firmware is 02HD.
The SSD is connected on the first S-ATA connector.
Still have the same problem on the third connector.
