Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem - "IRST Err - Download IRST 10.5 or above" on new desktop with 60GB Corsair Force 3 SATA 3 SSD
I need help solving a problem with firmware, software and/or hardware.
On new desktop from ibuypower, when Windows 7 Pro comes up, popup labeled "IRST Error" says "Install IRST 10.5 or above."
In system tray, there is a green checkmark by IRST saying system is functioning normally, but that does not confirm IRST is using the 60GB SSD correctly.
The IRST system report seems to show 10.6.0.1002 is already installed. Either Intel or the computer refuse to intall 10.6.0.1022. I've tried it repeatedly. It appears to install then tells me to reboot, but yet no update. Either way it is IRST 10.5 or above so the reason for the error is unknown.
The SSD is supposed to be 60GB Corsair F-series SATA3. Belarc Advisor, ASTRA32 do not tell me anything to confirm this, but Intel's IRST manager seems to confirm. I already know the system builders at Ibuypower installed the wrong DVD burner and the wrong RAM and don't know what else is screwed up.
http://www.corsair.com/ssd/force-series-3/force-series-3-60gb-sata-3-6gbps-solid-state-hard-drive.ht... http://www.corsair.com/ssd/force-ser...ard-drive.html
System Report
System Information
OS name: Microsoft Windows 7 Professional
OS version: 6.1.7601 Service Pack 1 7601
System name: OFFICE-PC
System manufacturer: Gigabyte Technology Co., Ltd.
System model: Z68X-UD4-B3
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3.701 GHz
BIOS: Award Software International, Inc., F6
Intel® Rapid Storage Technology
Kit installed: 10.6.0.1002
User interface version: 10.6.0.1002
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 10.5.0.1034
Driver version: 10.6.0.1002
ISDI version: 10.6.0.1002
Device Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: Volume_0000
Number of disks: 1
Array disk: 11246518000007435830
Status: Normal
Type: RAID 0
Usage: Cache volume
Data stripe size: 128 KB
Write-back cache: Disabled
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 1
Disk on port 0
Port location: Internal
Status: Normal
Type: Solid-state drive
Usage: Cache device
Serial number: 11246518000007435830
Model: Corsair Force 3 SSD
Firmware: 1.2
Password protected: No
Native command queuing: Yes
SATA transfer rate: 6 Gb/s
Disk on port 1
Status: Normal
Type: Hard disk
Usage: Accelerated disk
Acceleration mode: Enhanced
Serial number: MN1220F31NS29D
Model: Hitachi HDS723020BLA642
Firmware: MN6OA5C0
System disk: Yes
Disk on port 5
Status: Normal
Usage: Unknown
Serial number:
Model: Optiarc DVD RW AD-7260S
Firmware: 1.03
System disk: No
Disk data cache: Disabled
Native command queuing: No
SATA transfer rate: 1.5 Gb/s
Physical sector size: 0 Bytes
Logical sector size: 0 Bytes
Empty port
Port: 2
Empty port
Port: 3
Empty port
Port: 4
Please let me know if you know the solution to the problem.
MBall5
New Contributor II
Sorry this is the Intel Solid state drive community, I suggest you to contact Corsair for further assistance on this issue.
