Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem with 110902HD88208850.iso but no CD, only usb
Hello all,
I have a INTEL SSDSA2M080G2GC and I would like to upgrade the firmware but the 110902HD88208850.iso file is useflul only with a CD writer which I don't have. Since my bios can boot from a usb key, how can I make it boot so I can upgrade my SSD disk ?
MC
Tags (2)
Community Manager
Exact same problem here, trying to update my new SSD that I installed in my netbook!
Community Manager
Hello Mactabilis,
I did the upgrade, have a look on this, it works pefectly :
As /message/71345# 71345 http://communities.intel.com/message/71345# 71345 didn't work I found a better way update to the new firmware from a USB-drive:
Before we start you'll have to Open "My Computer". Either from Start Menu or by hitting the Windows Button + E. Now in the new window, press ALT button. Select Tools, then Folder Options. Under View select "Show hidden files, folders, and drives". Also uncheck "Hide protected operating files". Select "Ok".
A) Download the latest firmware, as we speak it's 02HD. http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363
B) Now you need a program like PowerISO or UltraISO to extract the content from the ISO file to a temporary folder of your choice.
C) One of the extracted files is config.sys. Open the file with notepad and make sure to remove the two "A:\". The file should look like like this afterwards:
DEVICE=HIMEM.EXELASTDRIVE=ZBUFFERS=20 FILES=40DOS=HIGH,UMBDOSDATA=UMBSHELLHIGH=command.com /P
D) Now navigate to http://www.vistax64.com/tutorials/191416-dos-usb-boot-drive.html http://www.vistax64.com/tutorials/191416-dos-usb-boot-drive.html and download the two zip files, win98boot.zip and HPUSBformattool.zip.
E) Unzip the win98boot.zip to a temporary folder of your choice.
F) Insert you USB-drive.
G) Extract the HPUSBFW.EXE from the downloaded HPUSBformattool.zip, and run the program.
H) Make sure the tool has selected the correct device. Pick FAT32. Check quick format. Check create a DOS startup disk and browse to the folder with the unzipped win98boot.zip files. Click start, yes and ok. Close the tool.
I) Now navigate to the extracted ISO files (the files we extracted in 2.) and copy them all EXCEPT command.com and paste them to the drive you just prepared with the HP tool.
J) Restart and enter BIOS to select your USB-drive as your primary boot device. Save and exit.
K) Now it should boot from your USB-drive and auto start the update proces.
Hope you can do it as I did !
best regards,
MC
Community Manager
It worked perfectly, thx a lot for sharing your information
Community Manager
You're welcome !
Bye from Paris,
MC
