Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem with SSD toolbox
I am trying to use the toolbox for the first time. But I already get stuck trying to select my SSD. All itt does is constantly refresh. My SSD is an 80GB Gen1 - could that be the problem? The OS is Windows7 X86. Here is the first screen that shows my SSD as first drive.
Community Manager
The SSD Toolbox should run fine. However, the SSD Optimizer only supports G2 and newer drives.
Community Manager
Thank you for the answer. That is kind of what I suspected. I wanted to "clean" my SSD. Can you recommend how to go about that. I have two of those Gen1 models and since there is no Trim, they must be "clogged". Your guidance would be appreciated.
Community Manager
I have the same problem but with a brand new 510 drive. Everytime I click on the SSD drive it refreshes the screen. I can click on the two SATA drives just fine.
Whats happening?
Community Manager
I have the same problem with my new 320 series.
Community Manager
Hello folks,
If you have an nforce motherboard and you have the nforce chipset installed you will need to change the SATA controllers in the device manger back to the windows default Standard Dual Channel controller to get the Intel SSD Toolbox to work.
Kind regards,
LukeF
