Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem with X25 V
Hi!
I have a very strange problem wiht my SSD from Intel. I use it to run WIndows Media Center (windows 7) and all scheduled tv recordings are stored on the SSD before they are copied to my Windows Home Server, and deleted from the WHS. The problem is that the recordings take up space on the SSD even after they are deleted. If I right click on the recorded tv folder and choose properties for the folder I see about 21 GB occupied space, but the folder is empty.
I have scheduled the SSD optimizer, and run the Intel tools and everything is green, but still, the disk think it is full. Only a reboot of the system solve the issue.
What is the problem? Is the SSD faulty? DO I need to use another driver? I haven't actually installed a driver for the SSD, but using the one in Win 7. I have the latest firmware also in the SSD.
HELP!
/Henrik
Community Manager
Hello MrNorth30,
The SSD optimizer works by letting the SSD know which Logical Block Addresses (LBAs) are associated with already deleted files. It should be "blind" to your OS -- you should not see a change in the amount of free space reported on a disc.
The fact that Windows is reporting that 21GB resides within the folder eliminates the SSD optimizer tool as the problem. I suspect that you may have some hidden files or something that is taking up the space yet the folder "seems" empty.
Can you kindly attempt the following:
Start --> Run --> Cmd (to open up a DOS prompt)
Navigate to the directory of interest.
>> dir /a (directory command with the "show all" switch)
I suspect that you will see files here.
Community Manager
Hi!
I already tried this, the folder is extremly empty, yet the OS reported 21 GB of data in 2 folders and 44 files. There are no folders and no files here, no hidden folders and no system folders.
I find this extremly wierd and is beginning to wonder if there is some kind of bug in the win7 driver... because when I reboot the PC, the correct amount of disk space is reported. Or the SSD is flawed somehow.
Zhdan_B_Intel
This might have nothing to do with SSD drive. I've seen similar issues before on HDDs (e.g. http://www.bleepingcomputer.com/forums/topic130053.html )
Is it possible to replace ssd with hdd just for testing? i think it's just an OS bug
