Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem with updating firmware on Intel X25-M.
Hello.
Bougth my SSD back in 2009, and the current firmware is 2CV102G9.
Wanted to update to the newest firmware to check if I get better performance.
I downloaded the newest firmware, and put it on a DVD as an image file.
But it won't boot correctly from the DVD.
It just keep saying "Enter the full shell command line:" and i got no idea what to write.
For other users, it seems it just go directly into the firmware update process.
Kinda stuck here. I'm using a USB DVD since i don't have anything else available at the moment.
Probably doesn't matter, but my motherboard is: Gigabyte Technology Co Ltd - X58A-UD3R - Socket 1366
Any ideas?
Tags (1)
Community Manager
The new Intel SSD Toolbox 3.0 can update the firmware for X25-M SATA SSDs (34nm) to 2CV102M3. Check it out at: http://www.intel.com/go/ssdtoolbox/ http://www.intel.com/go/ssdtoolbox/.
Community Manager
That doesn't work for my SSD
Community Manager
Ok. Found the problem after some google searching.
The problem is USB CD Drive. For some reason the firmware updater won't load from that.
Solution: Use a SATA CD Drive or create an bootable USB Flash Drive.
