Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Problem with win 7 64bit on new Intel x25-m 80 gb
Just made a clean install,on Intel x25-m (Firmware: 2CV102HD) with intel_msm_8.9.4.1004-full(http://www.station-drivers.com www.station-drivers.com) drivers (the 64bit
loaded under the installation) install INF Update Utility Ver:9.1.1.1025 then msm_8.9.4.1004 and its working fine.
install a couple of games and its runing nice ( 264Mb/s read in crystaldiskmark2.2) then...
i plug in my netkable and as soon as i setup my network, Windows 7 prompt me to select the type of location.
Once i select Home Network, (Windows 7 will start applying the necessary settings for my new network) i register
windows 7 no problem
but after ca 10 min got this errors.........and it is lacking
The driver detected a controller error on \ Device \ HardDisk0 \ DR0.
and i Matrix Storage Manager im back to generation 1...
still same drivers under my controller ( and now 84 Mb/s read in crystaldiskmark2.2) after reboot im back to generation 2 i Matrix Storage Manager
but 2 min later im in with the same problem...any idea what windows are doing?
thanks in advance
Tags (1)
MBall5
New Contributor II
Hello, I would like to let you know that so far at the lab and with that Solid State Drive we test Windows* 7 and it works just fine using the 64 bit version, I will suggest to perform a secure erase and try to install the operating system, if that does not work you can add the Solid State Drive in a working operating system and format or initialize the Solid State Drive and then try to install Windows* 7 64 bit operating system.
