cancel
Showing results for
Search instead for
Did you mean:
Problems to install Windows 7
Esteemed Contributor III
Hi! I have a problem that somehow is connected to my X25-80Gb SSD-drive.
Have built a PC on a Gigabyte GA-P55-UD3 motherboard. Everything has worked fine until I got to the OS-installation.
The intention was to install the OS on the SSD-drive. The installation works fine up until a certain stage where the intallation ALWAYS freezes.
The PC just stalls, and NOTHING happens...
I get to the point where the installation says "Completing installation"...and then...nothing....I 've waited over night just to make sure that nothing was going on in the background...but nothing.
Once I replaced the SSD-drive with a disk-drive....then everything worked, so I sent the SSD-drive back.....the retailer tested it, and found that it worked fine, so I got it back....same problem still remains.
What have i tried more?
Disconnected all USB-equipment. Nothing
Changed from IDE to AHCI in Bios, and back. Nothing
Another DVD.Nothing
To me there seems to be something that makes my motherboard refuse to install on the SSD-drive. Is there any specific settings that the MB may require?
Anybody have any ideas? Do I need to buy another MB to get this working?
Very greatful for any suggestions!
BR from Sweden.
6 REPLIES 6
OK, just so anyone with the same problem knows......I replaced with a ASUS MoBo...and an new processor, and then the installation went just fine!
(P8P67LE)
Björn
I have kinda similar problem but with intel 510 series it's connected through 6gbs ... what should I do? I changed it back to ide and it works again
