Community
cancel
Showing results for
Search instead for
Did you mean:
BBato
Problems with video editing after upgrading to ssd.
Hi all,
I upgraded my hard drive in my laptop to an Intel Pro 1500 series 180gb ssd. Before I had been using just a standard mechanical hard drive. Everything is of course much faster except for one thing - video editing. No matter which editing software I use, no matter what type of video I import, the preview window always lags (drops frames) This makes me unable to do any editing as the preview window is important to see what the video looks like. The preview window never used to stutter when I had my old HDD so I came to the conclusion that the problem must lay with the ssd. My specs are as follows:
Lenovo G470 Laptop
Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (with integrated graphics)
8 GB DDR3 Ram
Intel Pro 1500 series 180gb SSD
Any help would be appreciated.
Jose_H_Intel1
Hi Baz_B, do you get similar behavior from different tasks, such as a file transfer? Please try copying a big file.
There are similar issues discussed across the web that make reference to other causes.
BBato
Hello joe_intel, thank you for your response.
I do not get similar behavior from copying big files - in fact it seems pretty fast doing such tasks. Bootup time is also pretty fast.
Baz_B
ASouz7
Hey Baz_B
We are currently researching on this issue for you. Please give us some time to provide you an answer.
ASouz7
Hey Baz_B,
We wonder if you could let us know and example of the firmware you tried. Please let us know as soon as possible.
BBato
Hello aleki_intel, thanks for your response.
By firmware, I'm guessing you mean software? If so, I have tried Sony Vegas Pro 13, Adobe Premiere Pro CS6 and Camtasia Studio 8.
Hope that is the right thing.
Baz_B
ASouz7
Baz_B
Exactly. I meant the software. Thank you for the information. we are going to research on this and see what we can find to help with this issue.
BBato
Thank you, I appreciate your confirmation.
ASouz7
Hello Baz_B
Please check the SSD is runing the latest firmware. You can find our Intel® Solid-State Drive Toolbox for downloading in the following link: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® Download Center Could you please also tell us the current O.S., the previous drive, and if the graphics drivers are updated?
BBato
Hi aleki_intel,
I have checked and I have the latest version of the Intel SSD Toolbox (I run the optimizer every week). My current O.S. is Windows 7 Ultimate 64 bit. I am not able to tell you exactly what my previous hard drive was (I have given it to someone else) but I can remember that it was by Toshiba and had a 240gb capacity. I have also used the Intel driver update utility which made me update the chipset and graphics card drivers but after installing there was no effect - the preview window is still laggy. (The drivers are up-to-date).
