Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
RST V9.6.0.1014. Does it pass the trim command through a raid array?
I know the help files in the RST GUI state that trim works for raid arrays in this driver release however is there an official word from Intel?
I've read that raid 0 arrays are not detected by the Toolbox. Is that because the toolbox needs to be updated?
Any official info would be appreciated.
MBall5
New Contributor II
Hello, I would like to let you know that the RAID limitation regarding the trim command is related directly with the hardware manufacture and the RAID controller not the Solid State Drive is what limits the trim command to work within the operating system.
